head/intake swap requirements?
RE: head/intake swap requirements?
head gaskets
intake gaskets
hardened push rods (new heads have stiffer springs)
a new tb and egr would be smart since youll need the extra flow.
arp head bolts or studs (studs are better)
intake gaskets
I just made my list but it would up being a lot more expensive than that. You'll need:
-Head Gaskets
-Intake manifold gaskets
-Headers gaskest
-Water pump gasket
-Pushrods
-Springs
-Valves
-Intake manifold bolts (if you can't reuse yours)
-Head bolts
-Coolant
-Oil and filter
If you're swapping the cam, add:
-Timing chain
-Timing cover gasket
-Oil pan gasket
-Head Gaskets
-Headers gaskest
-Water pump gasket
-Pushrods
-Springs
-Valves
-Head bolts
-Coolant
-Oil and filter
-Timing chain
-Oil pan gasket
You dont need water pump gaskets for a h/c swap. I forgot about the oil and filter though.
ORIGINAL: VigCS
-Head Gaskets
-Headers gaskest
-Water pump gasket
-Pushrods
-Springs
-Valves
-Head bolts
-Coolant
-Oil and filter
-Timing chain
-Oil pan gasket
-Head Gaskets
-Headers gaskest
-Water pump gasket
-Pushrods
-Springs
-Valves
-Head bolts
-Coolant
-Oil and filter
-Timing chain
-Oil pan gasket
I'm an engine retard so bear with with me... I thought that with a head swap one had to adjust the valves after the install to ensure proper clearance? I'm I wrong.... educate me.
ORIGINAL: Texas5.0
Austin - you're right.
So... If I bought a set of AFR's all I have to do is pull my stock heads off, replace some gaskets and minors like that and bolt the news on... thats it. No adjustments needed?
