Convertible pump, or motor problems.
Old 04-22-2007, 11:04 AM
Mustang1994
Mustang1994's Avatar
Default Convertible pump, or motor problems.
I don't know if it's called the pump or motor. But my drivers side, lets call it lifter, was spitting up flupid from the part where the lift rod goes in and out. Now is it just a ring that needs changing? Or is it an indication that it needs a new one. And can I go to a part store to get that fluid cause i'm sure it leaked all out when I was pulling down my top.
Mustang1994 is offline
Old 04-22-2007, 11:55 AM
Gary H
Gary H's Avatar
Default RE: Convertible pump, or motor problems.
Seals are toast, get a new cylinder. Be carefull when changing it, the lines to it can become brittle. Dont ask how I know, I have a new set of lines to put in..[:@]
Gary H is offline
Old 04-22-2007, 12:30 PM
Mustang1994
So I have to get a whole new one I just can't change the rings? That horrible
Old 04-22-2007, 12:31 PM
Mustang1994
What about the fluid, where did you get it?
Old 04-22-2007, 01:34 PM
vt89gtvert
vt89gtvert's Avatar
Just use automatic transmission fluid for the fluid. If you check the Convertible section there is a good description I wrote a couple months ago that will help you in filling it and the like. Pretty simple really, just not a whole lotta room to work.
vt89gtvert is offline
Old 04-22-2007, 03:28 PM
Mustang1994
Ok thanks
Old 04-23-2007, 01:11 AM
vt89gtvert
vt89gtvert's Avatar
To check the fluid level remove the filler plug located on the right side of the pump/motor assembly and check the fluid level. It should be level with the bottom of the filler plug hole. To fill it I always used transmission oil. But fill it with the top down. The leaking could easily be leaking. Imagine the following senario:
The top is up and you fill up the pump. Now you lower the top and the pressure increases and blows out the o-ring.
Old 04-23-2007, 01:29 AM
Mustang1994
Great thanks!
importsmasher
10-09-2015 04:42 PM
ChampInSD
10-02-2015 04:55 AM
5.0 kevo
09-03-2015 06:24 PM
joe73Qcode
08-15-2015 09:49 AM
Quick Reply: Convertible pump, or motor problems.
