1987 mustang
RE: 1987 mustang
Its not true but its definitly recommended. I have an 87 and I have small camshaft in it and a intake manifold as well as full exhaust. Now due to the camshaft my car has a slight surge at idle but an idle plate and restriction in the map sensor vacuum line have made it pretty steady.
RE: 1987 mustang
You either have to switch to MAF, or if you keep SD you need to make sure the car will idle well(decent idle cam, no big intakes etc, have to have good idle vac, no vac fluxuations) and if you change anything on SD you have to retune the computer(if it changes theVE of the engine significantly)to get best performancesince the lookup tables in it are based on the engine as it came from the factory. Just switch to MAF, be WAY easier in the long run and make tuning/performance options much less of a hastle. Or run a carb
RE: 1987 mustang
thanks everyone for your help so far. right now i have full exhaust and a cold air intake and will soon have my shift kit and 3:73 gears in, but im looking at putting heads on there from my buddys 91GT there stock GT heads but have been hoged out and that stuff with 1.7 roller rockers. and i want to put a E303 in it to anyone think that would be ok for now intill i swap to mass air
RE: 1987 mustang
ORIGINAL: slowfox
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
