H/C/I Project Underway!!
RE: H/C/I Project Underway!!
ive been tearing my motor apart fora little while now as well, the zip lock bags are a beautiful thing and write on them with a marker a despription of were they were located and things close by... good luck with everything
ORIGINAL: backfire2007
what kind of pistons are you running?
mm&ff says you can run stock pistons w/ TF kit, summit says stock wont clear[sm=wtf.gif]
I am going on top of my stock block...I figure if the bottom cannot handle a new top...then I will buy a new bottom.
The guy at Summit said it the best...I asked if he thinks if I should do the block as well as the heads and he said. "that is a conversation that you and your wallet needs to have"
Unfortunately, my wallet...and my wife said NO!!
But everything else I got still keeps me with a smile...at least for now
ORIGINAL: CantStopTheFox...
I went with the TrickFlow Steat-Heat Kit... http://store.summitracing.com/partde...p;autoview=sku
With some extra goodies:
Ford Racing Lifters
Air:
BBK 70mm TB
BBK 75mm EGR
BBK CAI
Ignition:
MSD 6al
MSD Coil
MSD Wires
MSD Cap/rotor
Exhaust:
BBK Ceramic unequal Shorty's
UPR X-Pipe w/cats
Fuel:
Ford Racing 24lb Injectors
Walbro 255lph pump
BBK Regulator
Suspension:
UPR upper/lower control arms
UPR full-length subframe connectors
Then I bought some gauges too...
Autometer Ultralite fuel pressure
Autometer Ultralite Tach
Autometer Ultralite Oil Pressure
It was like Christmas!!!!
Hopefully I will get it all on while I have the time...I took leave all week!!
ORIGINAL: VigCS
What heads/cam/intake are going on?
Ford Racing Lifters
Air:
BBK 70mm TB
BBK 75mm EGR
BBK CAI
Ignition:
MSD 6al
MSD Coil
MSD Wires
MSD Cap/rotor
Exhaust:
UPR X-Pipe w/cats
Fuel:
Walbro 255lph pump
BBK Regulator
Suspension:
Why did you get a 70mm throttle body but a 75mm EGR spacer???? I also didn't see a MAF on there that matches the 24 lb injectors.
ORIGINAL: greenstreak9205
you didnt have the motor at "T.D.C." when you took that last pic did you?
