front end vibration
RE: front end vibration
Yes. Quick check, Pick a front corner of the car, put your weight on it and push up and down a couple of times. Car should stop jouncing after about the first or second bounce. If it keeps going then you have bad struts.
Other reasons you can vibrate at speeds, tires need balancing, broken steel braid in tire, or bent rim.
