How bad are the stock intakes?
How bad are the stock intakes? I had to replace my edelbrock performer RPM intake for a stock intake. I also had a 70mm TB and a 75mm Maf and 30 lb injectors. Those are all stock things now. I have a 306 with TF TW heads and an Anderson B-41 cam. How mismatched will it be with the stock intake?
RE: How bad are the stock intakes?
Yeah, bunch of my stuff got stolen and I dont have enough money to replace it at the moment. Stock stuff was free, and I just need it to drive right now. Whats wrong with the cam? When I upgrade back to a better intake, I was thinking a TF Track Heat. Would I be better off with the Performer RPM or the Track Heat?
ORIGINAL: 2 kwik
to get an idea put your hand over your mouth and breath..get the picture
think about is you have what 2.02 heads and and a fairly radical cam, and you have the stock t/b 60mm with small stock intake runners with 19's that are maxed...this is why I SAID to stay out of it with no high rpm blasts...then work to get new parts ..used parts can be your friend
