How do you...
Old 04-24-2007, 01:00 AM
94RedDevil
94RedDevil's Avatar
Default How do you...
How the hell do you get the damn power steering pump off of the bracket on an SN-95??? I just disconnected the ps pump and took it, and the head off at the same time then pulled the bracket off. I wanna paint the bracket but i cant get the ps pump off to do it. Btw...HCI in progress
94RedDevil is offline
Old 04-24-2007, 01:03 AM
67mustang302
67mustang302's Avatar
Default RE: How do you...
Did you take the pulley off?
67mustang302 is offline
Old 04-24-2007, 01:07 AM
94RedDevil
94RedDevil's Avatar
its impossible to get the pulley off, i put the hex key in and it was tight as hell, couldnt turn it, so i got a long tube that i have sitting around the garage for leverage and i bent the hex key, so i dont see that thing coming off. A buddy of mine told me that it was pressed on...dont know how true that is but i do know that that bitch aint comin off
Old 04-24-2007, 01:12 AM
Joel5.0
Joel5.0's Avatar
Need a P/S pulley puller.......
Joel5.0 is offline
Old 04-24-2007, 01:14 AM
67mustang302
It is pressed on, your buddy was right. You'll need to get a p/s pulley remover, bolt it back onto the bracket, and put the bracket in a vice since it's off the car now. The puller has a sort of u shaped "cup" that slips over the lip on the center of the pulley, and as you screw a bolt in, it presses it off the pump. To reinstall it you have to get a bolt that threads into the shaft on the pump, and a nut on the bolt with a washer, put the pulley on, thread the bolt/nut/washer in, and get the bolt in as tight as you can get it, then holding the bolt you run the nut down so you're pressing the washer against the pulley, hold the bolt with one wrench and turn the nut with the other, and EVENTUALLY the pulley will get pressed all the way back on. Just make sure you get it completely on. And YES, it is a pain in the rump....one more reason I ain't got p/s
67mustang302
Or get a puller like the one above, there's a few different styles
Adam03GT
04-09-2007 11:19 PM
Quick Reply: How do you...
