Supercharger Opinion!!!!!!!!!!!!
#51
RE: Supercharger Opinion!!!!!!!!!!!!
Just go to www.tweecer.com and you can read about them there but you can't buy direct through ten. You can go to a link on their page and it will tell you who the authorized dealers are.
It's one of my favorite toys for the car. There's so much stuff you can do with one. You can adjust and change displacement, spark, fuel, MAF functions, shift points, TV pressure, speed limiters, rev limiters, plus a bunch of other things. basically it lets you mess around and create the perfect tune. Then you can change the tune by simply turning a ****.
EDITED TO ADD: I use the tweecer RT to datalog my runs, either on the dyno or on the street. Then I cna play it back later and look at every little aspect of my run. A/F ratio, MAF voltage, RPM, speed, throttle position, gear, injector duty cycle and pulse width, boost level, spark advance, airflow, etc. That way I can replay the run a few dozen times to figure out what I need to change before testing it again.
#53
ORIGINAL: cassidymustang
thanks for that. i didnt see anything about it so i assume it doesnt read your KR?
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
