OMG Brake Lines
RE: OMG Brake Lines
Ill take a pic give me a second... I snapped it off now I cant connect my new lines... is there any way to fix this problem or can I buy a new line? My steel line fitting snapped off on both sides now!!! for fuc* sakes now im stuck I lubed the hell out of thoes damn lines and they still seized up and broke on me.
RE: OMG Brake Lines
follow that line up to the master cylinder. it should screw right into the master. unscrew it from there and replace the whole line.
edit: is that the drivers side front? if so, it goes to the master. if its the passenger side, it goes to a proportioning valve.
RE: OMG Brake Lines
RE: OMG Brake Lines
if you really want to, go ahead. that kit is probably pre-bent and it would be a fairly easy install, but i dont see the need to spend $170 on brake lines when you can re-do all of them for less than $30 by going to your local parts store and buying a whole bunch of lines and a few compression fittings, just incase.
RE: OMG Brake Lines
Thats the kit. Just plain steel is about $20 cheaper but id go on and get the stainless stuff. 5.0 Resto sells them also but I dont know how the prices compare.
5.0 Resto is cheaper. Picture is just a rep. photo.
http://www.latemodelrestoration.com/...1&comp=LRS
