351 swap?
RE: 351 swap?
umm, old mustangs, trucks, full sized cars until the early 80s. trucks and vans until the mid 90's
btw......
btw......
HOW TO BUILD A 450 HP 460 ci
The request for information for a mild 450 hp street motor comes up weekly, so I thought we'd compile a list of parts that will accomplish this goal. Obviously, there is quite a bit of room for interpretation and variance on parts, but a good SEARCH will help sure up any remaining questions.
750cfm Carb
Edelbrock Performer, Performer RPM, or Weiand Stealth
Hydraulic flat tappet cam with approx 215-220* intake/225-230* exhaust duration. Lift should be in the .525" area to take advantage of the quicker lobes allowed by larger diameter lifters in Fords.
Examples would be the Comp XE262H or Lunati 61602
Compression should be around 9:0-9.5:1
Stock rods and crank can be used with good resizing and good bolts used
Heads should preferably be D0VE or D3VE
Exhaust valves should be increased to 1.75" size
Intake valve size does not need to be increased at this level, stainless valves are suggested over heavily used stockers
Port work on the exhaust side should be considered MANDATORY at this level. Thermactor removed, bowl blended to the larger seat, casting flash removed, exhaust bolt boss flattened. The better the work, the better it will run. To get to a real 450 hp level, it would be very beneficial to at least clean up the intake side, the seat to bowl blend at minimum. A good 3 angle valve job is mandatory. A D3VE head does have enough potential for this build but may require more short turn work on the exhaust side to match the DOVE. An aggressive cam like the Lunati probably requires the screw in stud conversion on the D3VE as well.
Exhaust should be minimum 1 3/4" headers to dual 2.5" pipes with good flowing mufflers. Manifolds will absolutely not allow the engine to perform as expected.
Roller rockers are not mandatory, but suggested. A HV oil pump is not required at this level, as the RPM level doesn't dictate loose tolerances. Standard .0025 and .0030 on rods and main should work fine, a bit tighter would probably be fine as well since the motor shouldn't see anything over 5500 rpm.
Good machining and port work should allow a motor like this to last forever, creating a solid 450 hp at around 4500 rpm and 525 ft lbs near 3500 rpm.
750cfm Carb
RE: 351 swap?
heres a link to swap kits that basically let you bolt up a big block
http://www.mspmall.com/ddautospec/swapkits.html
RE: 351 swap?
ORIGINAL: sleeper_inc
I hope I find either that engine or a 351 (what cars did they come in again?)
RE: 351 swap?
ORIGINAL: 89Ford
haha you cant scroll up...lazy bastard....look for the econoline vans them seem pretty popular in them...when i went to the junk yard all the vans had a 351 in them
77, thats some sick power!!!! I don't much money though[:@] I'll deffinatly try to find that engine when I hit the junk yard this weekend
Matt's 95 Stang
10-05-2015 07:16 AM
