What should I do
What should I do
Hey guys,
I know I haven't posted much but I would really appreciate any suggestion on this. I have little money this spring for some mods, looking at maybe 1500 -2000 $ (Damn, buying a house ) Anyways all I have done to my 91 GT is LongTUbes and Flowmaster exaust. What would be my next step toward some HP ? Throttle body ? Intake ? Distrubutor/Wires ? Gears (currently have stock gears), Suspension ? My plan is to eventulaly have a perfect engine to throw on a SuperCharger.
Thanks for the input guys.
RE: What should I do
Gears would be a good next choice. That will not give you any additional power, but it will help apply the power in a more efficient manner.
Then again, with a little more than $2k, you could get the h/c/i combo from trick flow. Then save up a few more bucks for the gears.
ORIGINAL: 87mustang347
yah gears are good if u have or no someone that can install them for u for free or cheap. any other machanic will charge at least $400
I'd go with new gears, like 3.73's and also a full rear end rebuild kit with new bearings and seals all around and have the shop rebuild the posi while they've got it out for the gear install. With the gears this might run you around $600 or so depending on prices in your area for labor. then I would go for some AFR 165 heads for around $1,300 new and you will really like the end results.
Cool, thanks guys! I'll go with gears for sure, most likely 3.73 and then I was also thinking the TrickFlow Kit Intake, TB 75mm and Cold Air. You think 75mm is too big for a stick engine?
