how do i install a brake booster in a 95gt???
RE: how do i install a brake booster in a 95gt???
ORIGINAL: grumpyphillips
I believe your gonna have to disconnect the brake lines. Also, that 1995 brake booster is going to be a really tight fit.
i have a 95gt and the booster neededs to be changed i bought a booster at autozone but just want to know how to install it do i need to remove the lines to the master cylinder?
unbolt the master cylinder from the booster and push it out of the way... you DO NOT have to disconnect the brake lines.
the booster however bolts onto the firewall from inside the passenger compartment.... so be prepared to squeeze up under the dash to get it out!
