Tuning a 94-95 5.0
Old 04-26-2007, 04:38 PM
w8less
w8less's Avatar
Default RE: Tuning a 94-95 5.0
basically get a computer friendly cam so it will be easier to tune.
my cam on the other hand was nowhere close to being computer frienly
560/576 300/310 110
the car was very moody and because of the computer tended to idle surge and then would just die sometime. at the time i had to deal with it cause i didn't have the money to get a tune
w8less is offline
Old 04-26-2007, 04:59 PM
drhoward
Penis Mod Erator
drhoward's Avatar
Just make sure you save up a little for a tune/tuner ofter words, it gets the most out of your setup anyways so you might as well
drhoward is offline
Old 04-26-2007, 05:22 PM
lecznar1
lecznar1's Avatar
nice... i plan on gettin my 95 gt late may so i'm already seein wat mods to put on it and with what combinations to make the most power.... want it to be a beast so i can beat my buddy's piece of shat srt-4.... i'm excited
lecznar1 is offline
Old 04-26-2007, 06:21 PM
samseed101
samseed101's Avatar
If you're looking for a great camshaft for a 1994 or 1995 GT and if you don't want to spend a ton of money trying to find the right tune then look into the Steeda #19 camshaft. It's perfect for these cars and needs very little tweaking (if any at all.)
samseed101 is offline
Old 04-26-2007, 07:51 PM
hawwk11
hawwk11's Avatar
ORIGINAL: samseed101
Thanks, for all the info. Speaking of camshafts... Is it worth it< and about how many horses could one expect from one?
hawwk11 is offline
Old 04-26-2007, 07:56 PM
AdderMk2
Banned
AdderMk2's Avatar
ORIGINAL: hawwk11
on a stock motor... dont expect the cam to do much except sound cool. You should pair it up with a nice set of heads and a matching intake. To get the best results out of it you should also get a 65-70mm TB and if you decide to get a larger MAF (our cars have a 70mm stock) you should look into a ford 80mm. toss on a nice exhaust and youll have a pretty bad *** machine
AdderMk2 is offline
Old 04-26-2007, 08:00 PM
samseed101
samseed101's Avatar
ORIGINAL: AdderMk2
ORIGINAL: hawwk11
Yeah, the cam alone won't do much of anything. The only reasin I still have it in there is because I didn't see the point in taking it back out after I swapped my heads and intake back to stock. I probably could have used it in the other engine I'm building but I can always pay $200 and get a decent cam anytime.
Old 04-26-2007, 08:03 PM
AdderMk2
Banned
AdderMk2's Avatar
your car, however, is an exception... you have a s/c.. so you WILL see gains from that cam
AdderMk2 is offline
Old 04-26-2007, 08:18 PM
hawwk11
hawwk11's Avatar
Thanks guys, so a cam will help an s/c engine, because thats what i plan to do when i get my 95, i want to s/c it but i want to leave the engine pretty stock.
hawwk11 is offline
Old 04-26-2007, 08:45 PM
AdderMk2
Banned
AdderMk2's Avatar
you are really wasting your money leaving the motor stock
AdderMk2 is offline
Quick Reply: Tuning a 94-95 5.0
