Gettin car dynoed in 3 hours.. Any guesses? RESULTS!!
#61
RE: Gettin car dynoed in 3 hours.. Any guesses?
ORIGINAL: hot85fifty
I cant load videos up on my computer. i dont have any software for it. yea gonna swap out one of my jets and it will fix the air fuel alot better than it is. but ill need to go on the dyno again to really tell how much it fixed it and what my numbers will be then. Im also gonna go when its colder then it was then. it was almost 90*.
#64
Your motor numbers seem kinda low. I saw a fox at my school with FRPP "Z" heads, GT40 intake, and an F cam, on a stock bottom end make 310whp. That was at 70 degrees though. I just answsered my own question.....you said it was 90 degrees when you dynoe'd right? How much spray were you usin?
#65
it was about 90* out. i sprayed 150 and it dynoed at 400 rwhp with way to much fuel. look at the air/fuel ratio. the dyno guy said if i fix that air fuel problem (lower the fuel jet size) it should be about 430rwhp. Also think about the size cam im using in this motor. its for a 302 and is way to small for a 331. also street legal unported regular twisted wedge heads.
who am i trying to impress? if you read the whole thing you would see that i was only doing this to see what it does before i port the heads, change cam, ignition, carb and whatever else i feel like doing.
lets see your dyno sheets and mod list.
#66
ORIGINAL: musclemustang94
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
