mixing 111 leaded gas with 91 unleaded gas
RE: mixing 111 leaded gas with 91 unleaded gas
lol dude you dont get it your gunna make adder very angry. just run 91 there is NO reason to run a mix or higher you will see lower numbers on the dyno expecially because your not gunna be running the high octain like that all the time. no mixing no 111 or what ever leaded just normal 91 unleaded
ORIGINAL: hot85fifty
what about 100? mixing them?
it seems like i pissed you off. lol. I just wanted to know if i should or not. it doesn't hurt to ask or get different opinions. and i said ok 91 then. like ok im gonna run 91.
If you are expecting a HP inscrease with the mix, then you will be highly disappointed... run the 91 and be happy...You're wasting money with that high octane
Running racing fuel on a normal compression engine is throwing money out your window. It will do for your car what a Folgers can exhaust tip does for a Honda.
