Have I forgotten anything? (HCI checklist)
So I'm doing my HCI in two weeks. I made a list of everything I need and I've checked it over a million times now...I have everything but want to make sure I haven't forgotten anything. So this is where I am and what I have:
-GT40P heads, new valves, seals, TFS springs, etc...
-Explorer upper and lower intakes
-B cam
-Assembly lube
-Full intake manifold gasket set (lower intake gaskets, upper intake gasket, front and rear seals, and some o rings)
-Timing cover gasket set (two water pump gaskets, timing cover gasket, oil seal, cork oil pan corner gaskets)
-Head gaskets
-Valve cover gaskets
-Trick flow adjustable timing chain set
-Hardened stock length pushrods
-BBK Chrome unequal shorties (new, new headers, bolts, etc...)
-ARP head bolts
-Belt
-Oil and coolant
I lost my list so I'm probably forgetting a few things from it. Thanks all, it's a big help!
What you guys have told me I need:
-Throttle body gasket set
-B cam
-Assembly lube
-Head gaskets
-ARP head bolts
-Belt
-Oil and coolant
RE: Have I forgotten anything? (HCI checklist)
ORIGINAL: capri debris
Should probably change all your coolant hoses and the t-stat. Also, you are gonna need a new T/B gasket set.
Depending on age check out the harmonic balancer and water pump.
Just a heads up, I'm not sure if foxes are different but both I and another kid i know tried to use a trickflow timing chain on our SN95s and neither fit correctly.
ORIGINAL: OnyxCobra
http://store.summitracing.com/partde...p;autoview=sku
That is what I've got.
ORIGINAL: VigCS
Water pump is new, don't know about balancer. I'm sure it's fine. Why wouldn't the timing set fit for you? I'm getting it from a kid who put a trick flow top end kit on and didn't use it.
ORIGINAL: OnyxCobra
