Replacing my stock headers
I apologize if this question has been asked from other people about a million times. I would like to replace my stock headers,but by doing a search I'm just not sure what I want to replace them with. I would like to get some suggestions from you guys on what I should do. As of now I have an x-pipe and SLP I mufflers. Should I replace them with shorty's or should I replace them with full length headers? Will replacing my stock headers improve the sound and hp output? The reason I ask this is because my stock headers look almost like there kinked a little bit and if I'm not mistaken I'm probably losing flow,right? Thankyou for any help you can offer me!!
RE: Replacing my stock headers
if you already invested in the X pipe then just go with the shorties, there isn't a grave enough difference b/t shorties and LTs to buy a new mid pipe, your better off buying shorties and then investing the money you would spend on the newmid pipe somewhere else
i agree. i was just wanderin if you had anything done to your motor if not you dont need long tubes anyways.
ORIGINAL: jewel91lx5.0
The motor is basically stock with a few add ons such as:
electric fan with 130 amp alternater
MSD blaster ignition/w spark plug wires,dist. cap,rotor
Accel coil
Hypertech chip Fully functional ram air
373 gears
Will replacing my headers with shorties help my hp at all considering that they are stock?--will it sound better? and is it normal that the stock headers are sort of "kinked"
Accel coil
373 gears
ORIGINAL: BlueDemon
