Gapping plugs.
RE: Gapping plugs.
ok i gapped my plugs 0.053 - 0.056 and took it out for a test drive. i did feel a difference in pull for sure. it just pulled harder in every gear, now my MSD ignition can really shine
RE: Gapping plugs.
when i gapped the plugs i noticed a power increase. the extra gap allows the MSD's big spark to be a big spark. if the gap is too close than the spark will be puny and the MSD ignition is practically worthless.
RE: Gapping plugs.
you can increase the plug gap with an MDS ignition as it makes plenty of power to jump the larger gap and make a bigger, hotter spark to light off the fuel/air mixture. and the material the plug is made of doens't have anything to do with the size of the plug gap you run, it justs makes the electrodes last longer is all. I'd run them at .055 or so and you'll get good results.
RE: Gapping plugs.
ORIGINAL: roundman
a typo? i never thought i would see the day!!!!!!!!
Omgitsa88Stang
10-05-2015 07:33 AM
JDWalton
09-24-2015 08:47 PM
stangin1996gt
09-21-2015 11:01 AM
