94 gt battery relocate
relocating battery to trunk. In the foxes i noticed starter coil is firewall but not in my 94. the wire that came with kit (taylor) is 18ft so I was thinking of running it to the electrical distribution box under hood, and then secure the existing old battery lead (with a ring terminal instead of battery lug) to the same connection. Anyone do this? recipe for disaster? also they give you threaded rod, nuts/washers to fasten box in trunk, I can get one in (next to fuel fill) but to use the other one it looks like i have to drop my tank [:@]. ideas? Ground to battery box bolt nut ok? the supplied ground wire is 18inches long[:@]Thanks guyz
