Any ideas?
Old 04-29-2007, 01:35 AM
5pointslow91
5pointslow91's Avatar
Default Any ideas?
1 of my injectors is sprayinggas all over the place, 1 of the 2screw ports used to hold the fuel rail to the manifold is cracked on 1 side and i cant fully tighten it. What can i do to stop it from spraying?
5pointslow91 is offline
Old 04-29-2007, 01:39 AM
67mustang302
67mustang302's Avatar
Default RE: Any ideas?
Go to carburetion
67mustang302 is offline
Old 04-29-2007, 01:41 AM
5pointslow91
just bought a holley systemax so no
Old 04-29-2007, 01:43 AM
67mustang302
You may have to replace the rail/injector(s). Is the injector cracked, or is it just spraying from where the fuel rail connects to it?
Old 04-29-2007, 04:47 AM
5pointslow91
it sprays from where the injector goes down into the manifold
Old 04-29-2007, 04:48 AM
mattdel
mattdel's Avatar
so the screw hole in the manifold is cracked?
mattdel is offline
Old 04-29-2007, 04:54 AM
5pointslow91
yes, and it only screws so far, the fuel rails arent snug and it seems like the injector does want to go down into the manifold all the way either
5pointslow91
does not*
Old 04-29-2007, 04:58 AM
mattdel
mattdel's Avatar
it will go in, as long as the rubber o-ring is the correct size. try putting some wd-40 or something equivalent on the o-ring, and pushing down on the rail, above that injector. it should pop in. after that, 1 screw SHOULD be enough to hold most of them tight, but I wouldn't be surprised if a couple of them leaked.
If you are still using a stock intake, I HIGHLY suggest you just purchase a stock lower intake from ebay or something... any kind of "fix" that a shop will offer you, to take care of that screw-hole, isn't going to work on aluminum.
mattdel is offline
Old 04-29-2007, 05:49 AM
5pointslow91
i have a holley systemax upper and lower manifold which i just installed
Quick Reply: Any ideas?
