T-5 Q
RE: T-5 Q
I know that in those rare Grand Am's they used that Synchro mesh fluid so that it can actually shift, but will it actually improve the shift quality in a T-5, or any other manual for that matter?
RE: T-5 Q
no... thats what the person told me when i got my car, he was wrong and it was way overfilled... take out the filler plug on the passenger side of the trans.... and the diff has a check bolt next to the drive shaft area... but only way to drain mine is pull the cover
also i heard lucas oil helps shifting, whats some opinions
RE: T-5 Q
No, there's to plugs on the passenger side of the tranny. One's to fill it up, the other is to drain it. Take out the drain plug, then the fill plug. Once it's all drained, put the drain plug back in, and then fill it up using the fill hole. You'll probably have to use a hose or pump to get it in there.
RE: T-5 Q
ORIGINAL: 86HOGT
RE: T-5 Q
ORIGINAL: teamtech
how would i pump it!
J/K On a serious note, you can buy a siphon pump at most auto parts stores which siphons the fluid out of the container and pumps it into the tranny via a long hose. They don't cost much.
