Holley's Systemax II Or Edelbrock Performer RPM II
Old May 1, 2007 | 01:31 PM
5.0Notch's Avatar
5.0Notch
Default Holley's Systemax II Or Edelbrock Performer RPM II
My car is in the shop doing the motor up..I'm going with a 306. but what intake manifold should i go with....thanks
Old May 1, 2007 | 01:53 PM
opertob's Avatar
opertob
Default RE: Holley's Systemax II Or Edelbrock Performer RPM II
I'll say holley sys 2, or TFS Track Heat (trickflow)
Old May 1, 2007 | 01:57 PM
cassidymustang's Avatar
cassidymustang
holley sysemax
Old May 1, 2007 | 02:06 PM
CrazyCobraSpeed's Avatar
CrazyCobraSpeed
those that answer obviously dont know much about matching intakes to the rest of you setup.... what heads are u using... what cam are u using... u didnt give ne info other than 306... which isnt really ne info at all.... what setup are u running... and intakes only purpose is to get the rite amount of air to you engine like you engine wants it... so its actaully more of a support mod... which means it needs to match with you heads and cam and if u run nitrous or s/c or t/c all that matters too.... throw out more info and iwll go form there.... gearing also matters... waht tranny and what gears are u running
Old May 1, 2007 | 02:46 PM
cassidymustang
ORIGINAL: CrazyCobraSpeed
True. But he just asked which out of the two he should get. and the 2 choices that he has given are about identical. So from what ive seen proven by people ive talked to or Magazines ive looked at or shops ive talked to, the Holley is better anyway you look at it. its suppost to flow better/more, n/a or s/c. so my answer is Holley regardless of what his mods are.
Old May 1, 2007 | 02:53 PM
CrazyCobraSpeed
thats fine and all im no downing you pick on intakes im telling him that u shouldnt pick out an intake without looking at all your opinions... and seeing as he didnt give much information it seems he may be a lil at a lose how to corecctly select an intake and i dont want him to screw himself over just bcuz he busys and intake that every says is good and it may be good just nto good for his setup... i wanna know what is setup is also his price range so u can pick out a perfect intake for him
Old May 1, 2007 | 06:55 PM
88ragtop's Avatar
88ragtop
You couldnt go wrong with either one. Both are pretty good.
Old May 1, 2007 | 07:00 PM
r.barn's Avatar
r.barn
Holley gets my vote
Old May 1, 2007 | 07:05 PM
rez_rocket's Avatar
rez_rocket
Holley
Old May 1, 2007 | 07:48 PM
5.0Notch's Avatar
5.0Notch
i'm sorry i should of gave more info. I'm new at this stuff..Heads GT40, E303 cam, 1.6 roller rockers, JBA headers, and i'm plan to put a supercharger when i get some extra cash..Will all that stuff match,like the cam, rr, heads,and i dont' know what size injectors or throttle body to go with..
