1500 to spend i need opinions
ok well i got about 1600 to spend. i know its not that much but what would be the best way to gain the most hp with that ammount here iis what i have currently.
stock block
.40 over flatop pistons
stock crank
e7 heads
.512 lift cam
3.73 gears
aod w/ shift kit
2 chamber flow masters
off road h pipe
i planned on turning into a carb setup so i went ahead and bought
victor jr intake
holley 650 double pumper
so let mek now what would do good.
stock block
stock crank
e7 heads
.512 lift cam
3.73 gears
aod w/ shift kit
off road h pipe
victor jr intake
RE: 1500 to spend i need opinions
ORIGINAL: chupac
You might want to look into a trans and torque converter if it's auto or clutch if std.
i'd say spend that money on suspension. you don't need HP to go fast.
Actually, you can get a good set of heads that will give you a 100HP increase over stock heads.
You can take a completely stock 302 engine and then add AFR165 heads, Tri-Y headers, and 1.7RRs. With that combo, you can make 400bhp. That's with a stock camshaft.
ORIGINAL: samseed101
how much better is afrs then like gt40x? i mean i found a deal 450$ for complete gt40x aluminum heads but if those are work it that much then i could do the afrs if i can find some cheap. i forgot to add i have to put 200$ away for a paint job..
what kind of suspension work are you talking? sub frame connectors? control arms? let me know i thought about that stuff
supercharger would only work if i was efi. im going carb.
btw.. i might be swappin over for a t5. never really drove a manual though.
[/align]
ORIGINAL: dthompson67
[/align]
[/align]
As far as the blower goes, that's not true. You can get superchargers and even turbochargers for carbed setups. Not as uncommon as you think.
