E85 Conversion for Carb 5.0
Yes I have read all the other threads about E85 and some people are for it and some are not really I dont care if you are for or against it. I just really want to know what is needed to be done to a stock 193 5.0 GT Carb so it can be safely run on E85. I was told that I should just get a racing kit for it since E85 is about the same effect on rubber parts as racing fuel. If this is true where can I get a kit to convert the carb, I have all ready done the fuel lines, filter, tank, and some other misc parts I just need to do the carb and fuel pump. But I was told that the pump that runs off the block would be fine for E85 I just got it like 2 months ago and the service people said it is all ready has non rubber seals.
And for you people that dont like it it is $.60 a gallon cheaper here then the 10% blend and regular gas, Yes I might get a little worse milage but it does produce for power because of the higher octane, but I dont think that the milage will be so much worse that is will account for a 60 cent difference per gallon.
RE: E85 Conversion for Carb 5.0
I would hazard a guess that E85 would also require pretty radical carburetor re-tuning too. If you ever travel to areas where its not available you might end up being stranded somewhere.
That's just a hunch though. I remember back in the 80s when they tried "gas-a-hol" that none of the carbed stuff ran worth a crap on it.
Basically set your car up like a methanol car for the strip, alchy carb etc, but you'll have to rejet it to account for the 15% gasoline content. And more than likely your mileage will be quite a bit worse, since methanol and ethanol run about 2.5x richer than gasoline, do the math. E85 in a carbureted car is gonna consume around 2x the fuel per mile that it would with gasoline, so considering the cost to convert to run E85 on a carb, and the mileage, unless the E85 costs less than half of what gasoline does, it may turn out to be a bust that burns a hole in your pocket. More power production actually comes from the BTU/lb in fuel, alchohol based fuels have less BTU/lb but sincethey run much richer stochiometricly compared to gasoline, they actually produce slightly more BTU overall than gasoline does. Just stuff to think about
Well that is why I am doing the conversion with the stock carb so I can compare to see what the actual numbers are because I have a new carb and intake waiting for me just want to see what this will do for fuel milage and power.
You have to get an alcohol carb, a plain holley's seals would just swell or deteriorate. E85 burns at about 8:1 or 7:1. The only reason I would do this swap is if you had a radical motor that you wanted to do more street driving with. I believe the octane of e85 is around 104 and you could get away with slightly higher compression then normal and run more timing. If its a stock motor there really is no point.
ORIGINAL: ZachW04Stang
bradleyb
11-27-2015 07:50 PM
Matt's 95 Stang
10-05-2015 07:16 AM
treesloth
09-28-2015 07:03 AM
