wire questions
wire questions
ok i need help wiring my deck. i wanna know if i should run all new wires since i cant figure it out or maybe you can help. the person who orginally had the car cut off the wire harness from the amp to the speakers, so i wanna know how to hard wire the speakers to the deck. here is a pic of the deck wires front and back left and right
http://i157.photobucket.com/albums/t...6/DSCN0067.jpg
this is a pic of wires where the wire harness was cut off from the stock amp.
http://i157.photobucket.com/albums/t...6/DSCN0065.jpg
my next ? is when i wire up my gauges can i wire my lights and power wire to the power wire to the deck withot sacrificing anything? also same with the ground wires for the gauges?
http://i157.photobucket.com/albums/t...6/DSCN0066.jpg
all your help would be great appreciated!!
RE: wire questions
the factory amp has to be bypassed for the speakers to work. i would run new wire from each speaker to the deck, then find the factory power wire and constant power then ground it. It's only 3 wires besides the speakers. You could always run the power right to your battery if you can;t figure it out
RE: wire questions
does anyone have an answer to my second question? can i run my lights from my gauges to the power wire of the gauges also the ground wire? they are so close and it would be so convenient
RE: wire questions
I have a question to add without starting a new thread. On mine, I have it hooked up as red constant power from battery, yellow switched. My stereo works but it will not retain any memory. I tried switching that wire combo and it wouldn't even turn on, what's the problem? how can I get the memory to work?
RE: wire questions
you red is the constant yellow is memory. so match up yellow to yellow and red to red and make sure you have a good ground. look at my last picture posted. those are your power and memory. to make it work all you need is red yellow and black hooked up the rest dont matter for working purposes. it will turn on with just those three. if it doesnt work if you flip them then something is not hooked up right, follow the wire back to the fuse
RE: wire questions
ORIGINAL: pastfast125
RE: wire questions
I just bought the two harnesses from Crutchfield when I bought my old Blaupunkt from them years ago...I have had a few decks since then but I kept the harnesses so I just connect them to the deck and amp wires and plug it in. Makes it much easier than rewiring the crap under there to bypass the amps.
