Need some expertise...head gasket?
My car has always smelled like burning fuel, especially at idle, mainly because I have no cats and dumped flows. But now when i give it gas a bluish/white smoke comes out. I'm hoping that it's air-fuel-ratio is whacked but i'm scared it's a blown head gasket. I'm not losing oil or coolant, I'm confused? Any comments, advice please! School get's out in a week and i need to drive it home100 miles!!!!
RE: Need some expertise...head gasket?
I haven't noticed any performance loss, but something is ****ed up. I am goin to pull the codes, could it maybe be the O2 sensors, or am i definately burning either oil or coolant.
I think my car might be doing something similar, or so Im told...I lose a quart of oil like every month, or every weekend if i drive the **** out of it. however, I never see smoke...
No, a blown head gasket would cause you to burn coolant. Blowing white smoke is the number one indicator, as well as power loss, watery oil, loss of coolant, or oil in the coolant. It's a serious problem that you have to have diagnosed before you drive too much. Watery oil could cause you to throw a bearing, and low coolant can cause overheating leading to cracked heads. If it's burning coolant, your exhaust will leave your hands really wet, and it will smell sweet. Look for white smoke under throttle.
Oil burning creates blue smoke...caused by oil bypassing the rings, or other internal problems.
Excess fuel burn causes black smoke, which is from a rich condition...bad O2's, etc.
It's not that noticable at idle, but is above 2500 rpms. I have to drive it home 100 miles next week and hope i don't fry a ring or crack something. The confusing part is that i haven't noticed any loss in performance or loss of coolant or oil. The oil level is high could that have something to do with it?
