Trick Flows, then send them to Fox Lake. They will make them even better. Even better than AFRs.
So spend as much on TFS as you would on AFR 165's then have them ported at extra cost to out flow AFR 165's instead of just buying a set of AFR 185's which will out flow ported TFS Wedges out of the box? Good thinking.................
And don't argue that 185's have larger runners then wedges, because if Fox Lake ports them they aren't 170cc runners anymore now are they..........
To answer the original question, AFR's. I have a set of 165's and I love them.
