Comp XE282 Roller
I have been looking at buying the cam stated above. I know there are a few of you guys out there running them. I got a couple of questions about it.
#1.Does the cam provide enough vaccum for the brakes and such? #2. What does the cars idle sound like, is it choppy? Anyone have a video of there car idling with an XE282 |
RE: Comp XE282 Roller
What are the specs on the cam?
It has a split duration/lift
Duration (adv.)-282 int./ 290 exh. Lift- 564int./ 574 exh. I had a flat tappet cam that was a 286 advertised with a .471 lift (summit) on stock truck heads and it had a nice choppy idle to it. I just have never ran a roller set up before. |
whats actual duration. advertised is basically useless
your gonna need a hell of a flycut to your pistons if you plan on running a lift that high.
also, i hope you have some SERIOUS heads, afr185's or bigger. |
ORIGINAL: BlessedHellride It has a split duration/lift Duration (adv.)-282 int./ 290 exh. Lift- 564int./ 574 exh. I had a flat tappet cam that was a 286 advertised with a .471 lift (summit) on stock truck heads and it had a nice choppy idle to it. I just have never ran a roller set up before. I thought you were talking somethin small but that cam is prolly a little to wicked for a stock car car with like a trickflow stage one or somethin unless you plan on forkin out the money for heads and intake then possibly a tune |
It's going in my 347, 190cc Aluminum Pro Comp heads that everyone dislikes. Carburetor set up.
I think the duration @ 50 is like 230int./240exh. |
I run the Comp Cam the size smaller than that, XE274HR with AFR 185's...it's nice, almost wish I wen with the 282 but mine has enough vacuum and streetabitlity, the 282 should too.
Call Comp they will steer you in the right direction. I have the next size smaller and like it alot, it has a lumpy idle. My car has 14 1/2" of vacuum at 900 rpm.
ORIGINAL: mattdel your gonna need a hell of a flycut to your pistons if you plan on running a lift that high. also, i hope you have some SERIOUS heads, afr185's or bigger. It's going in my 347, 190cc Aluminum Pro Comp heads that everyone dislikes. Carburetor set up. I think the duration @ 50 is like 230int./240exh. |
