camshafts
RE: camshafts
ORIGINAL: gearbanger
you dont need stronger springs...
ORIGINAL: gizim_1132
You should just be able to put it in but heads and a intake would compliment that cam alot but you will have to change your valve springs to stonger springs
RE: camshafts
ORIGINAL: carsurplus
ohk how bout a wet nitrous kit for my stock engine or what can i put on there that will give me more horsepower other then internals
RE: camshafts
You have to change the springs to match the cam and you really shouldn't put nitrous in with stock pistons it won't last long at all put gears in exhaust, cai, bigger throttle body, it's not all about horsepower to make a car fast try some suspension mods
RE: camshafts
R u a rookie around cars you need to know how to check backlash and everything when you install the gears but if you haven't really been around cars very much just pay someone to do it or get a friend to help you out so if you do mess it up you can blame them
RE: camshafts
na my knowledge of cars i alot its just that i havent done gears and im still learning i need the experience i have a shop my father owns a carquest run mechanic shop so i get there help also
