Strugglin with Tie Rod Replacement. need advice
RE: Strugglin with Tie Rod Replacement. need advice
ORIGINAL: 2 kwik
if you go with a Manuel rack just get one for a Granada..it's a 4 door stang
ORIGINAL: 2 kwik
you will need the manual tie rods ends....the rack islike 90 bux @ autozone
ford uses trany fluid for p/s, the high acid content helps prevent build up.. but its highly recommended you change it out every year or so due to its high acidity... not good for seals
ORIGINAL: decipha
if tranny fluid wasn't good for seals, car manufacturers would be requiring tranny seal replacements yearly.
ORIGINAL: 2 kwik
$hit I don't use tranny fliud in mine
and yes it's way cheaper and you know it will last as long or longer than that overpriced flaming river crap
