Speedo Gear Question
hey guys i have an 89 with an AOD in it. I just ordered a set of Motive 4:10's for it and was wodnering what I need to correct the speedometer?
According to Steeda, I know I need the 7 Tooth drive gear with the 23 tooth speedomter gear since my car is an 89. Do I also need the gear on the mainshaft also? Or do I just need the gear on the speedometer itself?
RE: Speedo Gear Question
you just need one gear for the speedo cable. i just put in a new speedo gear last week. my buddy who helped pull the tranny when we had it rebuilt was in a rush and stripped my old one. i just got around to putting the new one in.[&:] very easy install. took about 5 minutes
what main gear are you talking about?
the gear on the main shaft. thats inside hte tailhousing. the one that the speedometer cable runs off of. But if i do just need to change the speedo gear on teh cable only, then ill go ahead. Thanks for the help. ill order it later this week after finals!
Luke9222
10-22-2015 11:55 PM
musnicki
09-23-2015 07:11 AM
