Do drag radials really make a big difference in traction?
In my car at any time in 1st gear, if I punch the tires just break loose. I have been thinking about drag radials for my next set of rear tires. Would they make a big difference? I am currently running $57 Khumo Ecsta 711 (245/50/16).
Thank you.
Thank you.
RE: Do drag radials really make a big difference in traction?
you won't beleive it until you try it. back when I was n/a I could punch it anywhere in first and at the top of 2nd and it would break the tires loose. no more breaking them loose anymore after that. seriously - and all I had were 245 wide Nitto's. Before those tires, at the track - I would feather it at like 1000 rpm to launch, shifting into 2nd I'd get sideways real bad, I'd spin pretty bad going into 3rd and bark 4th every time I shifted. After the tires, I launched at 2500 rpm and could bark 2nd. No more 3rd and no more 4th. (stock clutch had some to do with that too).
i was thinkin bout some sometime... but how many miles could you get out of them if you drove on them daily? im lookin for 2 good tires in the back that will last a decent amount, without burning out either... how many miles out of em? 9k? more? less? thanks alot i really wanna know
if i walked into les shwab or whatever.... how much would they charge me for 2 tires 245's or widest that will ift mounted and balanced? any ideas? ... are bfgs better? they must be softer since you get less outa em
buddy of mine pulled 1.6 60 on them. if tires are cold they will spin. i can spin my et streets when they are cold. once hot then you wont spin
Well I will either be putting 17" drag radials on these 2 cobra wheels that I will be getting or I will just get 16" d/r's and run them all the time.
