Paint
Old 05-02-2007, 11:21 PM
86_GT_Mustang
Default Paint
How much will it caust to paint my 86 Gloss black?
We will be doing it our self.
Thanks
86_GT_Mustang is offline
Old 05-02-2007, 11:26 PM
blkonblk5.0
Default RE: Paint
Ithink at least $1000 for all the materials and paint if you are doing it yourself..
blkonblk5.0 is offline
sLoWnStEaDy
Default RE: Paint
anywhere from $300-infinity and beyond
depends on what type of paint, what brand of paint,what type of gun, the skill of the painter(s), how good the prep work is (black is a BIIAAATCH) etc... etc...
cars i have painted:
primer, sand paper, and paint under $500
http://aycu01.webshots.com/image/149...5467384_rs.jpg
sand paper, paint andclear coat right around $800 (never cut or buffed the clear which is more $$$)
http://aycu19.webshots.com/image/167...6970485_rs.jpg
sand paper and paint/clear around $400
http://aycu27.webshots.com/image/146...8565856_rs.jpg
there are more, but like i said it all depends...
sLoWnStEaDy is offline
Old 05-02-2007, 11:28 PM
creekrat
Default RE: Paint
If you use cheaper singlepaint , you can get what you need for around 250. Thats primer w/ activator, paint, reducer, activator for paint, and wax and oil remover. This is taking into account you already have necessary supplies like tape, masking paper, sand paper, tack rags, and spray equipment, etc
creekrat is offline
blkonblk5.0
Default RE: Paint
the paint itself could cost 200-300 a quart, and your probley gonna need a gallon
Old 05-02-2007, 11:32 PM
dthompson67
Default RE: Paint
at oreily the orange im looking at with reducer and everything else, hardner and such with clearcoat will be about 160$. add 30$ for gallon of primer. add little bit from laquer thinner, sandpaper and then thats it. im in the process of painting my car.
dthompson67 is offline
Old 05-02-2007, 11:33 PM
dthompson67
Default RE: Paint
since i will be a single stage easy gloss black it would be cheap.
Old 05-02-2007, 11:42 PM
JD1969
Pro. B.S. caller outer
JD1969's Avatar
Default RE: Paint
ORIGINAL: 92Mustanglx
Thanks
Unless you REALLY know what your doing I do NOTadvise you to paint your carblack for your first paint job. Black requires the body work to be PERFECT, if it is less than perfect the car will look very bad. Go with a lighter color like silver or somthing.
JD1969 is offline
Old 05-02-2007, 11:44 PM
86_GT_Mustang
Default RE: Paint
ORIGINAL: JD1969
Thanks
My dad has had experince painting with black on cars
Old 05-02-2007, 11:58 PM
86 GT 5.0
Default RE: Paint
All materials cost me 500 bones.. It was dupont.
86 GT 5.0 is offline
guitarman376
10-11-2015 01:47 AM
The New S550 2015-2020 Mustang
10-01-2015 09:29 AM
mungodrums
09-28-2015 10:54 PM
GLOCKer
09-28-2015 07:36 AM
mustangchef
09-04-2015 08:08 PM
Quick Reply: Paint
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
