electric fan?
RE: electric fan?
my fan is out of a 84 camaro, i had to make custom brackets.... works just fine... i went to kregans automotive and bought a adujustable thermostat.... it was only 15 bucks, very worth it, then i went to radio shack and bought a 30amp 12v relay for 5 bucks and hooked it up so my fan comes on when key is on and engine is warm enough, works just fine for me, i used to use a manual switch when i first got my car, i forgot to turn it on a few times and got it pretty hot... 15 bucks is well worth it, its a great setup
RE: electric fan?
so after you install an electric fan, what do you do with the old pully? take it off and re route the belt? now im interested in getting one! would be nice so that when its cold out i can warm my car up quicker, then flick the fan on....can you have it go on a thermostat but override it when you want to?
RE: electric fan?
Hm, this was useful, i was actually going to the junkyard this monday to see if there is a ford Contour or Taurus I can take the fan from. The double fan they have work pretty well for my friend, but I want to know, how easy is it to hook up to work? Is there some kind of auto on-off switch or does it simply come on when I start my car and shut off when my car stops?
RE: electric fan?
ORIGINAL: teamtech
ORIGINAL: bobby
should i ask for the switch too? should i install the termostat and the switch or just the switch? how do these install? thanks
RE: electric fan?
I have a cooling fan out of a 2001 Volvo S80 in my car.Im still working on setting it up with the temp controls.For now I use a toggle switch for when I need it.The fan was easy to find.There is a recall on the fans for the module going bad.Remove the module and the fan works perfect.The module controls low,med,high.Just remove the module and a you have a good fan.The Volvo dealers doing the recall throw the fan in the dumpster.So free fans if anyone lives near a Volvo dealer.I got the overflow bottle installed on mine and looks almost factory.Check out the pic.
RE: electric fan?
mustang8719, that setup looks wayyyyyy better then mine... mine looks like crap but does work LOL..... who would want a manual switch tho? radio shack has a relay you could use, you hook it up to the battery, then to the fan, then to a ground and to any wire that will turn on with the key, that way you dont even have to worry about forgetin it.. this would only be useful if you had a thermostat to turn fans on at certin temp tho... witch costed me 15 bucks and took 5 minuts to instal... well worth everything... i forgot to turn my switch on a few times and got er pretty hot
