throttle sticking
throttle sticking
my pedal sticks when i push down the gas. now this is only like a year old cable because my old one would stick but it's been sitting for a while now so i think that's why it sticks. can i just spray some wd40 in there? or do i have to get a new one?
RE: throttle sticking
check the cable routing, it might be binding up somewhere. also check the throttle body butterfly. make sure its not sticking inside.
also check under the dash. you might have some wiring holding the pedal, or even the floormat.
i checked the mat but that's all fine. yea i have to give it a good amount of pressure to get it going... afte that it's like cutting butter. i tried holding down the throttle cable past its initial part under the hood and spraying that spring and stuff but didn't work
