MSD Starter Saver
MSD Starter Saver
RE: MSD Starter Saver
all the starter save does is retard your timing so the car will start easier.
If you remove your spout connector, your car will run at 15°
If you wire a relay in place of the spout connector and power to it from a power souce that is only 12v+ while the key is in the RUN posityion, but 0v+ in the start position... Your car will crank at 15°BTDC timing advance, and will only go into full computer timing advance once started!
logan409
09-26-2015 07:43 PM
jaiidutch
09-14-2015 10:29 AM
