fmu
RE: fmu
Yeah, it will work just the same, as long as you have some form of boost. All it does is restrict / close off th fuel return line and causes a huge spike in fuel pressure. That, in turn, forces more fuel through your injectors, thus making them work as if they are larger.
It can put a strain on your fuel system though. I'd advise larger injectors, pump, and MAF. Chances are, if you're creating that much boost then you've probably maxed out your MAF anyway.
madsella
10-20-2005 10:16 PM
