stupid maf question
RE: stupid maf question
yeah he has the flow sheet for it, also to my other buddy has a cl with a green tube for 42lb injectors he doesnt need would that be better for me to pick up he only wants like 90 for it
there both good choices.. maybe 75.00 for the C/L
1 problem with the pro is I'm still not sure who does the calibration now since the by out thing that happened aways back this you might want ot look into
You probably should have waited before buying that C&L. That's a draw through and it sounds like you have a blow through setup. You should have been looking for blow through MAFs.
NM. I guess it is a draw through after all. I was having trouble understanding what you were saying at first. Didn't sound like the MAF was on the inlet side.
As you already know, it's better if you have the flowsheet. Then you can take it to a tuner and have it done the right way instead of trying to trick the EEC with a calibration tube.
