i have a pretty loud knock or maybe a tick and when i raise the hood it sounds like it's coming from the valve cover on the passenger side what do you guys think it could be.
if you think its a rocker hitting a valve cover... logic would dictate that you should remove that valve cover and look for internal damage or signs of contact....
but sometimes logical thinking is too difficult for some people
Nicely stated...your description is as hard to diagnose as can be. If you didn't check VC clearance then most likely solution SHUT THE CAR OFF...pull the covers and FIND THE CAUSE before your brand new motor possibly becomes the motor your currently rebuilding.
