Why isn't reverse sync'd????
Old 05-05-2007, 01:15 PM
88droptopgt
88droptopgt's Avatar
Default Why isn't reverse sync'd????
Why why why why? Cost cutting measure to not sync the rev gear in 5sp in these 5 o's?
88droptopgt is offline
Old 05-05-2007, 01:33 PM
5.0stanger
5.0stanger's Avatar
Default RE: Why isn't reverse sync'd????
Probably so it wouldn't go into reverse while you are moving.
5.0stanger is offline
Old 05-05-2007, 02:53 PM
Scalihoo
Scalihoo's Avatar
who cares if it's synched just do the ole put her in first before reverse, been that way for many years
Scalihoo is offline
Old 05-05-2007, 03:08 PM
capri debris
capri debris's Avatar
ORIGINAL: Scalihoo
1st gear syncro gets the most abuse as it is... so why put more on it... use 4th ot 5th gear, then put it in reverse.
capri debris is offline
tmajikman
tmajikman's Avatar
ORIGINAL: Scalihoo
Thats what I have to do also.
tmajikman is offline
Old 05-05-2007, 03:11 PM
HACKGT350
HACKGT350's Avatar
does it really matter? just throw it in a forward gear and then in reverse no problem
HACKGT350 is offline
Old 05-05-2007, 03:24 PM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
Its like that so you cant toss it into reverse while moving forward. Put it in 5th before you go into reverse, and it'll slide right in
WhiteFoxGT is offline
Old 05-05-2007, 04:05 PM
2 kwik
I ♥ Acer
2 kwik's Avatar
it doesn't need one as most people aren't moving when you shift into reverse
2 kwik is offline
Old 05-05-2007, 04:11 PM
91stang
91stang's Avatar
ORIGINAL: WhiteFoxGT
that's what i do but sometimes i still can't get it in
91stang is offline
Old 05-05-2007, 05:00 PM
67mustang302
67mustang302's Avatar
Whether you're moving or not has nothing to do with it, if you engage the clutch in neutral the input shaft on the tranny gets power and spins, and when you disengage the clutch and try to put in it reverse you're attempting to mesh gears on a moving input shaftwith a non-moving output shaft. Just cuz the car ain't moving doesn't mean tranny parts aren't. But yeah, just synch in a forward gear then rev. I use 1st on my toploader(it's quickest becuase reverse is 1 over to the left of 1st) and have no problems with it.
67mustang302 is offline
Quick Reply: Why isn't reverse sync'd????
