Rear Defrost??
RE: Rear Defrost??
You can check the coil lines on your rear window with a volt meter as long as your window isn't tinted.The rear defroster coils are very touchy.If the window has been tinted in the past and the tint was removed and they nicked one of the coils. If the coil was nicked or cut all the way through it will brake the circuit.First check for power at the solder joint at the window.Then follow the coils carefully and check for power and see if you lose it anywhere along the way.
RE: Rear Defrost??
You can check around for ideas I really dont have any.Everytime I found that problem on the car was when im working at a Dealership and we replace the window.Sucks that it comes down to that.But im really not sure of a repair.
RE: Rear Defrost??
i found a link how to repair a strip if this is your problem.
http://popularmechanics.com/automoti...air_defroster/
