Engine Build Plans
RE: Engine Build Plans
HCI and KB with all the upgrades required will cost you nearly the same plus or minus a few hundred depending on the heads. Your going to need FP upgrade, Injector upgrade, Maf upgrade, gaskets, hardware....easy grand right there...oh yeah and it will need to be tune..add 500 or you'll be rebuilding her by the end of the yr if not much sooner.
if your going to rebuild the whole engine get 185s, youd be leaving hp on the table with the 165s and there practically the same price. With the flowzilla it could definitly use the bigger head.
Just throw the $5,000 hellion turbo kit on your stock car.
It keeps all smog stuff
It comes with everything from MAF, Injectors and Fuel pump
Complete and they keep them in stock
Will add....... 200rwhp
go from 190rwhp to 390-400rwhp on bone stock engine
double your power.
Put some heads and cam on later
Perfect artcl for you.
http://www.musclemustangfastfords.co..._051100_turbo/
double your power.
Gary Ugarek
63
12-11-2015 02:01 PM
Calizic
08-28-2015 01:46 PM
HIS S-197
08-10-2015 05:47 PM
