Definately the fuel pump?
Ive checked everything. My car will crank, fire, run up to 1500rpm, then immediately die. I changed the plugs, checked the wires, cleaned the cap and rotor. I am getting spark from the coil and the plugs are firing fine. I took off the air box and it does the same thing so its getting air. Now to the fuel system. The fuel pump primes, the relay is clicking and working perfectly. the fuel pump inertia switch is bypassed. Fuel does come out of the rail after its primed, but not an excessive amount. So I have someone crank the car. As soon as it fires I start spraying carb cleaner into the throttle body. The car will idle and run perfectly as long as I do this. I stop spraying and it stumbles then dies. Does this pretty much guarantee it the fuel pump. I also changed the fuel filter beforehand. Thanks for your help. Also if I prime it like 50 times it will stay running a little longer. I actually thought I fixed it and it was idleing fine so I got of the car and it died. Im assuming the fuel pump is priming but not supplying fuel when the car is running.
RE: Definately the fuel pump?
What pressures will I be looking for on the gauge? What pressure primed engine off, and what pressure engine idling. The only way I can check the fuel pressure when Idling though is if I spray the carb cleaner and hold it.
The pressure should be around 30 at idle with the vacuum on the regulator, with the vacuum off it should be around 40. It could just be a bad regulator. Put the gage on, and watch it while someone bumps the key on, then starts it, if the pressure doesn't hold, could be a bad pump.
You change your fuel filter yet?
although the BBK pump is a walbro pump.... you can get it is a "walbro" for cheaper.... and get the 255... too big is not a problem... however, further down the road, if you need a bigger pump than the 190, youll have to buy another ump... you could just do it right... now
Ok it looks like Im getting the 255LPH pump. Since everything is 20 years old I will be replacing the tank, the sending unit, and the pump at the same time. I only want to do this once. My question is will the new sending unit need to be adjusted or can I just install it and be done with it? With my luck I will just install it and the gas gauge will be wrong.
