Carb size
RE: Carb size
should have a holley from the factory anyways. spend your money on a better intake, the stock early/mid 80's aluminum 4bbl intake has VERY small ports on it, much smaller than the stock heads have. basically its a restriction, and a stock replacement style intake with normal sized ports will serve you great. edelbrock performers are worthless, but the weiand stealth or action plus, or the edelbrock performer rpm or rpm airgap will work great on there - even with everything else stock.
RE: Carb size
there ya go!!!!
actually, while the rpm airgap is better for the higher rpm range and it keeps things a little cooler - the regular rpm doesnt have the center divider cut down and will do better at lower RPMs
i'd strike a deal with 87 if you can
RE: Carb size
ORIGINAL: 87black snake
i gotta performer RPM intake brand new in the box for sale if it helps ya! i'll even throw in the carb studs and Edelbrock chrome air filter housing new too
PM me or email lejenkatona@hotmail.com
Daddys Girls GTs
09-14-2015 08:46 PM
jaiidutch
09-14-2015 10:29 AM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
