chrome pony r's slow me down?
#22
RE: chrome pony r's slow me down?
There will be less rotating mass w/ the fifteens not to mention the weight difference if you go w/ an aluminum wheel. If I can ever make it to the track I'll be able to let you know. I just went from 17" steel wheels to 15" aluminum. There was a huge difference in weight!!
#24
every 10lbs you can take off the wheels is supposed to be 0.1 ET faster. i weighed my chrome ponies with tires and the total was around 180lbs then i weighed my turbines with tires and it came out to around 160, plus theyre an inch shorter so everything else constant it should be at least 2 tenths faster at the track
#26
ORIGINAL: Blue Oval
if you ran a 14.466 and lost 20 pounds in wheel weight your et would be 14.440, not 14.266
Test Configurations
Test 1
(2) 15x7 rally with BFG P215/60R15 = 95.56 lbs.
(2) 15x8 rally with M/T 26x10.5-15 = 93.70 lbs.
Total weight = 189.26 lbs
e.t. and mph = 12.137@111.99[/align]
Test 2
(2) 15x4 rally with M/T 26x7.5-15 = 70.86 lbs.
Total weight = 164.56 lbs.
e.t. and mph = 12.107@112.52
[/align]
Test 3
(2) 15x7 Center Line with BFG P215/60R15 = 70.46 lbs.
(2) 15x8 Center Line with M/T 26x10.5-15 = 64.10 lbs.
(4) Center Line center caps = 0.96 lb.
Total weight = 135.52 lbs.
e.t. and mph = 12.103@112.10
[/align]
Test 4
(2) 15x4 Center Line with M/T 26x4.5-15 = 42.12 lbs.
(2) 15x8 Center Line with M/T 26x10.5-15 = 64.1 lbs.
Total weight = 107.18 lbs.
e.t. and mph = 12.026@113.11[/align]
Total weight reduction = 82.08 lbs.
Total performance gain = -0.111 sec, +1.12 mph[/align]
#29
put it this way i went .89 quicker in the 1/4 with slicks n skinnies over my 17 inch cobra Rs. the cobra Rs are about as heavy as the Pony Rs, just put some draglites on it, notch's look sick with them, and you will go faster.
