cam upgrade
cam upgrade
hey wats up guys well i have my motor torn down to the block im replacing all gaskets and freeze plus i want to up grade my cam so i can get some more top end. now the heads that i have now are some ported e7 wich came with the car the heads were rebuilt about 6,000 miles ago. i was thinking of getting a FRPP alphabet cam but not sure wich one to go with i want to keep my stock valvtrain or replace it if i have to due to the cam thanx guys
RE: cam upgrade
Stage 1 wouldn't be too bad, it's relatively mild. A Steeda #19 is also comparable. Like rcd said, stay away from the alphabet cams. There's a lot more technology into the newer ones. If you're running the E7's you're going to have to replace the valve springs no matter what you do. What are your other mods? If you don't have much else done the money is much better spent saving up for an intake, as you won't see much benefit from a cam
RE: cam upgrade
oh i see well i have a 93'cobra intake manifold add on k&n h-pipe and flowmaster 40 but thats about it i was thinking of doing the cam, 65mm throttle body and a bigger mass air flow sensor
RE: cam upgrade
I have a B303.
http://videos.streetfire.net/search/B-303/0/c7e99313-4dea-4f09-9dac-98f7015da8bc.htm
Wait until half way through that movie and the car starts loping when the idle comes down.
RE: cam upgrade
kool ill take a look at it that was i was thinking about a b303 but i dont want to replace spring, notching pistons and all that stuff thats why i was aking did u replace any thin from your valvetrain to swap in that cam
RE: cam upgrade
Yeah, with what you got you might pickup 10-15hp top end(and that's being nice), but in all likelyhood it'll be less, and you'll just lose power most everywhere else too and end up being just as fast, or slower, but with worse mileage. Save up to do an h/c/i. Alphabet cams are only good if you can get it for $50 [8D]
