proper way to burn out???
RE: proper way to burn out???
with my automatic i take it right through the water and then stand on the brake and stomp the gas
works well enough for me cuz i always have the biggest burnout, then agian i am in Trophy Stock
ORIGINAL: FuzzyDiceRule
..., i mean, should youy do an actual burnout to get the water off, or still just spin em and hope for the best
You should never heat street tires, they will accaully ball rubber up on them and you wilol get les traction. Just spin them good as you go to the line.
ORIGINAL: 5.0stanger
ORIGINAL: telsonman
but are you essentially just dumping the clutch??? or is there a certain way to do it. i'm talking pedal work here
ORIGINAL: CantStopTheFox...
Hold the brake.......lift the clutch and press the gas.....all while holding the brake....and let them roll!!
I would not really consider it "dropping the clutch"
I can't seem to do it very well that way...it is called heel toeing it. Seems like I either burn my clutch or over rev. I like the dump then grab....I might be looking into a line lock.
Dumping the clutch is kinda harsh I'm a heel toe person its easy for me to do with my size 10.5 REDWINGS
plus I operate alot of heavy equipment and thats mostly heel toe all day long
dam I love my JOB !!!
lincolnshibuya
12-08-2015 04:37 PM
09-25-2015 06:42 PM
yourmom6990
09-14-2015 10:52 PM
