tranny fluid replacement
i just drained my tranny fluid and put some new fluid in...my question is how much do i need roughly...i know you fill it up to the bottom of the hole but the guy at jegs only gave me 2 quarts i think its close but have no idea...anybody have any clue how roughly how much fluid it takes to fill it up to the hole?
RE: tranny fluid replacement
I just had mine done in my 89. I watched the guy doit and he was having a tough time with it. He used just about the two bottles, eventually it started pouring out, he gave it a second then put the plug in when it was almost done draining.
well i filled the rearend with 2 quarts of fluid and its still not full...wtf...im never listening to the idiots a jegs again...is this right...should it take over 2 quarts to fill the rearend up to the fill plug?
ORIGINAL: CHILLERMAN
Friction modifier is only available at a Ford dealer. If your using Royal Purple synthetics then you don't need it.
