Nutral Saftey Switch?
#21
RE: Nutral Saftey Switch?
ORIGINAL: mattdel
i would need to have a wiring diagram in front of me to figure this out, this is strange. that switch prevents the key from sending a signal to the solenoid.
it shouldn't be killing the whole electrical system. it has to be shorting against another bare wire somewhere.
[IMG]local://upfiles/55564/F40C62FE095C479AAEDB72E135ADE42B.gif[/IMG]
#22
Pin 46 Blk/white runs to all the sensors, anyway what i dont get still is the no power, thats when the egine wants to die when it IS running, not like its throwing things off its just wants to die, maybe i should pull the negative off the battery once the engine is running to see if it can run on its own?
ANd what sht clutch sense switch too?
#24
Hmmmm....that could be, ill have to check, there are som many wires all over the place, doesnt look orgainzed at all, i would have ziptied everything if i h ad done the work
#27
So you think i can scan the Ecm and see what i get...? ALso forgot to mention when ive scanned it before ive always gotten and #67-
Nuetral ...switch or circuit/ or
AC clutch switch circuit
Wich the AC clutch doesn engage, i have no refridgarant.......yet
