Speed Density tricks
RE: Speed Density tricks
no offence... im not impressed.... i run SD, and know a good deal about it. and my only mods are, no cats, dumped mufflers and a tire, and i run 14.2s.... stock 3.08 gear too.... now i have some cheap front suspension mods.... after i get a new clutch ill run it again, should see a 13.9, havent yet been able to launch hard on the DRs because of the clutch. and hell when all my suspension is done, i plan on seein atleast 13.5, might get a gear, but dont know yet, doubtful right now. my **** will run a low lowl 13, or high 12 while its SD, al i have to do is put the suspension and another $500 into it...
as for screw sd convert to mass air.... your a dumb ***. depending what you want to do, sd is not bad at all... stock for stock its faster. and with a few mods, still staying sd, high 12s arent that far off.
and original poster, i gotta ask... whyd you waste the time/money to port the lower intake? its not the bottleneck, the stock heads are....
It doesnt help to port the upper without some sort of head work. I am gonna port both upper and lower when i get my gt-40 stuff. I have the stock E7 heads that i am gonna finish porting. I am doing as much of a budget build as i can.
ORIGINAL: SuperFox88
